Hi, First of all, I am not to sure if this is where i am suppose to post this kind of question. I am currently trying to convert a wireless application, that runs a wireless card using the linux-wlan-ng drivers. My goal is to make this application run with the newest hostAP drivers, but I am having trouble accomplishing this task. Here is the code that currently runs with the linux-wlan-ng drivers..
//Original code // //--------------------------------------------------------------------
#define LINUX_WLAN_NG 0x89f1 /*used by linux-wlan */ #define LENGTH 16 /* Max length of a device name */ request_t req; /* The formal request to the ioctl
//Fill in the request req.len = MSGSIZE; req.data = msg; req.result = 0; req.magic = MAGIC; strncpy(req.name, name, LENGTH);
//Open the socket to the prism2 card s = socket(AF_INET, SOCK_STREAM, 0);
if(-1 == s) { perror("Could not open socket"); ret = ERR; }
//Perform the ioctl call if(0 == ret) { if(ioctl(s, LINUX_WLAN_NG , &req) == -1) { perror("Bad ioctl request"); ret = ERR; } } return ret; }
Now my problem is I am really not to sure how I would go about modifying this code so that it does the same (communicate), using the hostAP drivers. Here is what I have so far..
struct iwreq iwr;
memset(&iwr, 0, sizeof(iwr)); strncpy(iwr.ifr_name, name, LENGTH); iwr.u.data.pointer = msg; iwr.u.data.length = MSGSIZE;
s = socket(AF_INET, SOCK_STREAM, 0); if(-1 == s) { perror("Could not open socket"); ret = ERR; }
if(0 == ret) { if (ioctl(s, /*NOT SURE WHAT HEX GOES HERE*/, &iwr) ==
return ret; }
This code compiles correctly, when I actually place a hex value in for the second aurgument of my ioctl call, but doesn't seem to communicate with the hostAP drivers correctly. I think my second aurgument in the ioctl call is incorrect.
Any help will be appreciated, I have been working on this problem for some time now, and I am looking for some ideas/help.
Thank You, Tom
