I am trying to set up this WS-5100 switch.
LAN on ETH2. 192.168.9.123/255.255.255.0 gateway 192.168.9.3
WLAN on ETH1. 192.168.31.20/255.255.255.0 Gateway : 192.168.31.1
I can see (ping https) switch fine from wired LAN. But can not ping anything on wireless side of switch.
I can ping adrress on ETH1 from wireless network but can not access anything on wired network.
I saw in manual that both ports need to have the same gateway. It also says that ETH1 and ETH2 can not be in the same broadcast domain.
If I try to put the "real" gateway in for the 192.168.31.x the switch locks-up.
If I try to give both ports 192.168.31.x addresses, the switch locks-up.
thanks.
dc
