Network Stumbler and Atheros AR5005G
Threaded View
I've an Atheros AR5005G WLAN in my Acer 9302 notebook. Network Stumbler
gives a message "No wireless adapter found".
In the menu>Device the adapter nework adapter is seen but it's displayed in
a grey text.
I'm running Vista. How can I solve this problem?  Do I have to get
additional software?
Thanks.
Re: Network Stumbler and Atheros AR5005G
Netstumber doesn't work under Vista.
<http://www.netstumbler.org/showthread.php?t=21558
You might wanna try this trick:
  start -> run -> cmd <enter>
  netsh                          (you should get a  netsh>  prompt)
  wlan show network              (simple output)
  wlan show networks mode=bssid  (all the good info)
  exit
Not exactly Netstumbler, but much quicker.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Site Timeline
