I'm trying to get an Apple iBook G4 with built-in Airport wireless capability to join an existing wireless network:
Linksys WAP11
-- "access point" operation mode
-- "shared key" authentication" using four WEP keys
-- the second of the WEP keys is the "Tx Key" (64 bit)
-- "infrastructure" mode
The iBook network configuration assistant recognizes and includes the SSID of the existing network in its dropdown list; I select the SSID, and then am prompted for a password. I don't know what password to enter since the network is using shared key authentication. I've tried the 2nd WEP key but that doesn't work: incorrect password error message. What should the password be?
Does Airport work with WEP encryption?
Thanks Timo
