Hi Everyone,
I am currently in the process of setting up a wireless network (home) and, from what I read in the internet, the best way of ensuring wireless security in the long run is by having either WPA2 or VPN enabled equipment.
I found a couple of ADSL modem/routers which I think would do, but I am not sure about the cost. The two devices are the Draytek Vigor 2800G and the Linksys WAG54GX2, both capable of running WPA2 and VPN networks.
The VPN seems to be better than WPA2, but do I really need both facilities in my router? Is there anything cheaper and equally (or sufficiently) good for home networking purposes? If I could choose between the two, which one would be better and easier to run?
Do these devices need NICs capable of WPA2 and VPN (with specific chipset), or can I simply use a 802.11g NIC and encrypt via some application in my computer?
Thank you for your help.
