Console install of OpenWRT
Hi all,
I need to install a text only version of OpenWRT on my router. I have never done this and not great with hardware so any advice is desprately needed. From a little googling I understand that I will need a 3.1V TTL serial connector and have got a vague idea where this will need to be plugged into.
Will a USB2Serial connector work?
My machine does not have a serial port on it so I will have to use a USB2Serial connection.
Is there a NIX based program that I can use to commincate to the routers serial port?
Any advice would be really appreciated
Aaron
IME USB-serial works fine through a TTL converter.
minicom.
alexd
Thanks heaps the exact advice I needed, will start researching it straight away
Aaron Spiteri
