I have recently upgraded two home PCs to Windows XP. Both PCs are connected via BT Voyager USB wireless network adapters. Aftre upgrading I had to reinstall the adapters as XP would not recognize them. The problem is that both adapters are finding it difficult to communicate. Both are installed properly with the same settings but for some reason they will not connect to each other(SSID). Any ideas please?
- posted
19 years ago
