BT Voyager 2091 Wireless connection
Jan 29, 2006 2 Replies
I've recently upgraded internet connection to BT Wireless with a BT Voyager 2091 router, and I have noticed several problems, which I hope can be resolved.
Firstly, when I turn off the router for the night, and turn it back on at morning, it takes ages for web pages to load (IE) or sometimes the don't load at all. It takes about 10 minutes for this to correct itself, and all the software packages that came with the router (wireless connection manager etc) say there is no connection.
Is it safe to leave it on at night? why does it take so long to load up?
My PC is the only thing connected to the router, and that is wirelessly. Is this a problem?
I also have a cordless telephone, which suffers from severe distortion when the router is on. Would this problem be resolved if the phone was changed to a DECT, or a corded phone?
Any answers/suggestions on these topics would be grateful.
Cheers,
Phil
You might try changing the channel that the wireless router is set to, if it's on 6, go to 1 or 11. As far as leaving the router on all night, that's fine as long as you have it plugged into a decent surge protector. It shouldn't take all that long when you turn it on each day. Make sure you have the settings saved for the router, otherwise it might be going through some sort of set-up routine each time. Good luck.
I tried changing the channel - it was on 5 - so I tried all the other channels, but no effect.
Would a DECT/digital cordless be any better, or would I have to change to a corded phone?
Cheers,
Phil
