Adding a WiFi "receiver" in the barn (200 feet from the house) using spare Mikrotik radios...
Would this work to add a receiver to the barn 200 feet from the house?
Here is a photo of the equipment I am trying to make good use of.
http://i.cubeupload.com/v7mpPx.gif
This is mostly a question for guys like Dan Purgert or Jeff Liebermann who
understand the Mikrotik equipment better than I do.
A neighbor switched from one WISP to another about a year ago, where the
first WISP told him to keep the equipment, so the neighbor gave me this.
[1] Mikrotik RB750 wired router
[2] Mikrotik RB411 motherboard + 2GHz/5GHz R52n-m WiFi daughterboard
[3] Associated antenna & pigtails & POE & power supplies & weatherproof box
Normally I turn all my spare transceiver radios into access points but this
is professional CPE equipment which doesn't have a license to be an access
point.
To make good use of the Mikrotik router and radio, I'm wondering if I can
plug the router into the 120VAC outlet in the barn (which is about 200 feet
away from the house), and then use a short Ethernet cable from this radio
pointed at the house to pick up an access point from inside the house.
The range isn't in question because I can easily beam the access point in
the house for a kilometer in good conditions so the question is really
simply whether the setup works that way.
I've never set up a wireless receiver before so that's why I ask.
I'm sure I could buy a dedicated wireless receiver but that's not the
question here.
The question here is how to make good use of this free equipment by setting
it up as a wireless receiver, so that I could plug in a laptop at the barn
into the router when I want to.
Site Timeline
