Can anyone shed any light on this? I've set up 3 trunks - Voiptalk, Voipfone and Sipgate. With Voipfone and Sipgate I get 2 way audio but with Voiptalk the other party can hear me but I can't hear them.
Voiptalk CS won't support trixbox at the moment, although they helpfully sent me a config that another customer had used successfully. If the problem was across all Carriers I'd suspect a NAT or port forwarding issue but with just one I'm scratching my head a bit.
Are you using SIP on Sipgate & Voipfone but IAX with Voiptalk?
If so, IAX requires a different (single) port to operate. Have you forwarded TCP / UDP or both?
Looking at their site it appears they support Asterisk, tell them your using Asterisk and get them to tell you what should be in the *.conf files and what ports should be set. Make a note, then add it to the freepbx interface later (will overight *.conf files).
I had the above in sip.conf under [general] but with the dyndns name. I removed it and put it in sip_nat.conf with the IP address. Still no joy. Re-booted linux/asterisk and made 1 call on Voiptalk - still one-way audio but subsequent attempts to call on this trunk get the asterisk lady telling me it's busy...
Aha, never mind, it's just that I had assumed you'd got it working - voiptalk had come up in an earlier thread (about the free signup for a geo number), where you'd had some probs.
I've also got this in extensions_custom.conf: [custom-voiptalk] exten => 12345678,1,Goto(ext-did,12345678,1)
I have also created an inbound route for 12345678.
I think I have a bit more in sip.conf:
port = 5060 ; Port to bind to (SIP is 5060) bindaddr = 0.0.0.0 ; Address to bind to (all addresses on machine) disallow=all allow=ulaw allow=alaw allow=gsm context = from-trunk ;defaultexpirey = 600 ; include this only if necessary ;maxexpirey = 3600 ; include this only if necessary progressinband = yes dtmfmode=auto
You're not the only one to mix those two up. Easily done! I was recently in email contact with someone and I sent them to voipfone instead of voiptalk. Not surprisingly, they couldn't find what I was talking about.
lol, :) yes, I know, but I thought that you had initial audio problems too and that maybe you'd had to adjust something to get it going OK. But now, looking back at that thread, I see that it was dialling format that was the problem.
