I have a Concord Express home alarm system monitored by Vector Security. They have so far been unable to help me with my question:
I have purchased an expensive portable generator to provide power during our frequent outages. The generator is stored in my garage, but must be wheeled outside to the driveway when it is in use. I would like to devise some sort of sensor that would trigger the alarm system if the security cable is cut or the sensor is disturbed. Can you suggest anything that might work? The generator will be run under cover, protected from rain/snow but open on the sides for ventilation. As an additional deterrent the generator will also be chained to a sturdy anchor system buried 36=94 in the ground.
