Needed: low profile module for embedding in a wall sconce. Starting with a WS467 as the base module, I did the neutral and SSR mods (idobartana.com) using a large 6A SSR. The smaller Crydom SSRs would have been nice but not on hand.
I'll hard wire the module address so I can toss the code selectors, plastic casing, metal front plate and the push-button assembly and then shorten the circuit board since I won't need the code wheels. Then I'll encase the module in epoxy. Because I am using the larger SSR it will be external, bolted to the inside of the metal wall plate as a heat sink. The epoxied module mounts between the wall plate and the metal base of the sconce.
The module minus the SSR can be as small as 40x43x16mm. Add 1mm per side for the outer dimensions of the epoxy block gets 42x45x18mm which is tiny when compared to an appliance, lamp or wall switch module. It's the 18mm dimension I need to be as small as possible.
I have a few questions about proceeding:
1-If I used the smaller Crydom could it be encased in the epoxy as well Do SSRs dissipate much heat?2-Are there any other components that would be thermally affected by being encased in epoxy. I'm thinking that (R2)1/2Watt 22ohm resistor looks like the only candidate.
3-Should I bother with the epoxy or just use a thin plastic membrane on all six sides ?My load on the module will be a CFL no more than 16 or 20Watt
