Hot or cold room improvement, AirFlow Breeze by Air Flow Technology
Found a great looking and effective product for assiting a stuborn hot or cold room that suffers from low airflow in the duct system. This little unit "Works" I am going to try and incorporate it in some of my projects, it has a good controler and runs on low voltage 12volt DC. It comes in most standard sizes and they are coming out with a
6x10 and 6x12 adaptor also.
See Link:
cpierce
I would say "nice spam" but if you are going to lie by pretending to be a customer with a good review, you should use an email address that isn't the maker of the product.
Overpriced small fan.
B Fuhrmann
Did you "find" this nice product by simply going to work? Seems your email is in the same domain as your "found" product website!
Do you th> Found a great looking and effective product for assiting a stuborn hot
AZ Woody
