Intercepting data flow between 2 applications by using a firewall
Feb 22, 2005 0 Replies
Is there a way for a firewall to log all the outgoing data flow from a localhost app to a remote server app, hence giving the user a chance to alter the outgoing data in a way that he sees fit?
I know that SPI Firewall can check incoming/outgoing traffic for virus matches against tehit databases but can they also log them so that one can modify ti a later time?
Thanks.
