I'm new to home automation. I just installed a DoorBell Fon (with the door lock controller). That's the full extent of what I've done so far. I'd like to add a keypad for front door access. I can't find a keypad that does what I want. I have a number of people that often need to get in and the people coming in change frequently, so I need something that can handle at least a dozen codes, some of which can be programmed as single use codes. That all seems to be possible with a number of the keypads out there. But I'm having trouble finding something that can log the codes used. This keypad does more than I need and says it offers an optional printer logging interface:
I know I could get a dumb keypad and have a computer controlling the whole thing. This would have lots of benefits. I could create one-time codes remotely. It would be easy to record and process codes entered, rather than just printing it as it came in. But I don't really want my door lock dependent on the rest of my network. I could probably pick up an old/cheap laptop (it would have battery backup) to use as a keypad controller, but if anyone has any other suggestions, I'd really appreciate the help.
Thanks.
