Hi there.
I'm getting the DS7000 and I live in Italy. I was wondering how to get the power conversion done .Is the power supply in the console convertible to 230V? I mean is there a step down transformer in the alarm console with primary windings which can be put in series support the 230V in my country? Or is purchasing a step down transformer a necessity?
I was also wondering whether the automatic dialing function will work over here. If not what modifications or tests should I carry out?
Thank you all for your advice.
Jim
