Hi Gain Antenna
Mar 30, 2006 3 Replies
Jump to replies (3)
Been looking all over the internet and in the electronics stores for a Hawking HWU54D hi gain antenna. Couple of friends bought them at Amazon .com a few months ago, but they are no longer available there - nor anywhere else it appears. This unit seems to do quite well for the particular application we have (boat in marina to shore router).
Does anyone know where one can be obtained -- or an alternate with equivalent range that works as well?
Jerry
See Marine in the Wi-Fi part of the FAQ below.
Signal Seeker Nothing beats a Signal Seeker for a portable wireless connection. Check Ebay look at feed back.
If it's a sailboat, you want a masthead-mounted wireless client with POE.
