CVBS video signal
I want to take a CVBS signal from a DVD player to the other end of the room, some 20'. What's the max length cable CVBS will run over (these are phono style connectors, not SCART ones)? Secondly, I already have an unused 75ohm aerial coax run buried in the building fabric and emerging in exactly the right places. Can I route the CVBS signal directly across this? What's the characteristic impedance of the CVBS phono type cable (I found a reference saying the SCART version is 75ohms)?
Andrew Gabriel
According to:
20 feet should be no problem for 75 ohm coax. But I never tried it myself.
regards, Johnny.
Johnny
Thanks for that. I need to buy a few connectors or adapters before I can check it out.
Andrew Gabriel
