Can anyone recommend a burglar alarm supplier in the US?
What i need is a dial out communicator only. All the PIR's, door and window switches will be connected to a smarthome system. The smart home system will then provide a single digital digital output to the burglar alarm. The alarm will effectivly be unset / set using the smarthome system. So i could get away with a single zone (input) burglar alarm with no keypad at all. A PCB only option would be even better as this could then be integrated into the smart home system control panel. The smart home system were delveloping wont be able to communicate to burglar alarm call centre systems etc.., mainly because we dont want to have to go through all the extra approvals needed.
Keith
