VPN/DMZ configuration help
Here's my config: WatchGuard Firebox x750e (version 8) WatchGuard Firebox SSL Core VPN (version 5.1) Public IP range: xxx.xxx.xxx.112/29 Private IP range: 192.168.10.0/24
Current Topology: Internet --- Cisco 1700 --- x750e --- LAN
Here is the config I am trying to achieve: Internet | Cisco 1700 | x750e --- (DMZ) SSL Core VPN (172.16.10.0/24) | LAN (192.168.10.0/24)
If I have three of my public IP address currently mapped to the external interface of the x750, how would I be able to give the external interface of the SSL VPN appliance a public IP? I need another IP block don't I? I think I am way overanalyzing this scenario so I have confused the mess out of myself. Thanks for any help.
Debo
You could put the 750e in Drop-In mode and then all interfaces would have the same addresses (meaning that LAN/DMZ would have the same IP as the EXT and then you create rules, same as in Routed Mode, to map ports between the Zones (LAN/DMZ).
You could also just forward the ports needed by the SSL to the VPN appliance from the IP you want to use.
Leythos
Thanks for your reply Leythos. So what you are saying is that if I want to run my SSL Core VPN in a true DMZ scenario I will have to change my x750e to drop-in mode? The second option you gave for port forwarding, if I use that I wouldn't have a true DMZ right?? So that means I would just hook up the one interface of the SSL Core VPN?? I called WatchGuard yesterday for some clarification and I am more confused now than I was before. Thanks again.
Debo
text -
This is the best I can do to help you:
Leythos
