Nokia IP60
Threaded View
Hi all,
I have just purchased a Nokia IP60. I want to manage this centrally from
my existing management station, but cannot find anywhere on the Nokia
how to establish the SIC.
Does anyone have any ideas?
Regards
James
Re: Nokia IP60
The IP60 is the same hardware/software as an Edge/sofaware appliance
and should be configured the same way:
- create an object UTM Edge/Embedded gateway object + fill in the
registration key
- connect your IP60 to the smartcenter using the same regisration key.
For more details check the CP documentation for UTM Edge.
Br.
Robby
Site Timeline
