Nokia IP380 + SmartDashBoard
Aug 12, 2004 1 Replies
Heres a stupid question I gotta ask:
I have just received our Nokia IP380 firewall and I consoled in and setup the interfaces with IPs and gave the device a hostname. The BIG question I have is how do I connect to the firewall (Checkpoint) to setup rules? I have SmartDashBoard on my laptop but I am not sure how to get it to connect to the Nokia IP380.
Any ideas?
Thanks!!!
Sean
Sean is alleged to have said in comp.security.firewalls:
First, in voyager, deactivate any CP packages you won't be using, SmartView Monitor, for example. The default, I believe, is still to have everything active. Then run cpconfig for the first time and tell it that's it's a stand alone install. Don't forget to add your IP or hostname as a GUI client and create an administrator. Finally start SD and use the user/pass you created, and type the IP or hostname of the box for SmartCenter Server.
