Hi Freaks
For a few weeks, I couldn't send emails :-( The error message is "Error 80042109 Outlook is unable to connect to your outgoing SMTP server"
So I did ask GMX, G-DATA, my internet provider, ... but no one can tell what's going on. GMX told me to switch of the (Window) firewall, no result.
Then I start the (windows) firewall logfile and got this:
2008-04-07 20:57:24 OPEN TCP 192.168.1.33 208.50.223.240 3187 80 - - -- - - - - -
2008-04-07 20:57:24 CLOSE TCP 192.168.1.33 208.50.223.240 3187 80 - -- - - - - - -
2008-04-07 20:57:34 OPEN TCP 192.168.1.33 213.165.64.21 3188 587 - - -- - - - - -
2008-04-07 20:57:34 CLOSE TCP 192.168.1.33 213.165.64.21 3188 587 - -- - - - - - -
2008-04-07 20:57:34 OPEN TCP 192.168.1.33 213.165.64.22 3190 110 - - -- - - - - -
2008-04-07 20:57:34 DROP TCP 213.165.64.21 192.168.1.33 587 3188 40 A 3429721974 3955125903 5840 - - - RECEIVE 2008-04-07 20:57:37 DROP TCP 213.165.64.21 192.168.1.33 587 3188 48 SA 3429721973 3955125903 5840 - - - RECEIVE 2008-04-07 20:57:43 DROP TCP 213.165.64.21 192.168.1.33 587 3188 48 SA 3429721973 3955125903 5840 - - - RECEIVE 2008-04-07 20:57:54 OPEN TCP 192.168.1.33 208.50.223.240 3191 80 - - -- - - - - -
2008-04-07 20:57:54 CLOSE TCP 192.168.1.33 208.50.223.240 3191 80 - -- - - - - - -
2008-04-07 20:57:55 DROP TCP 213.165.64.21 192.168.1.33 587 3188 48 SA 3429721973 3955125903 5840 - - - RECEIVE 2008-04-07 20:58:19 DROP TCP 213.165.64.21 192.168.1.33 587 3188 48 SA 3429721973 3955125903 5840 - - - RECEIVE 2008-04-07 20:58:24 OPEN TCP 192.168.1.33 208.50.223.240 3192 80 - - -- - - - - -
2008-04-07 20:58:25 CLOSE TCP 192.168.1.33 208.50.223.240 3192 80 - -- - - - - - -
2008-04-07 20:58:26 OPEN TCP 192.168.1.33 213.165.64.22 3194 110 - - -- - - - - -
2008-04-07 20:58:26 OPEN TCP 192.168.1.33 213.165.64.21 3195 587 - - -- - - - - -
2008-04-07 20:58:26 CLOSE TCP 192.168.1.33 213.165.64.21 3195 587 - -- - - - - - -
2008-04-07 20:58:28 CLOSE TCP 192.168.1.33 213.165.64.22 3194 110 - -- - - - - - -
Aha, there are DROPs Try to open the port 587: no connection at all
Does anyone do have any idea what's going on?
BTW 1: I did try Thunderbird: Same problem BTW 2: OS Windows XP Pro SP2
regards Ingo
