It's a trick. It's just a java applet that shows you your internal IP. Only you can see it.
If I go with my windows PC (any browser) to the URL
How do they get my internal IP?
Is it a bug in my iptables-Firewall, or ist it a trick of them to sell firewall software?
thanks in advance
Markus
ok, I found it, the page called a page named "/adt.asp". this page calls a java applet named "auditmypc.class" and the Class get the IP on clientside. Mozilla does't shows the Internal IP, because the adblock of my mozilla blocks the first Iframe.
Here the "(de)coded" javascript code:
##### inside scanoptions.asp: ###### document.write('\\u003c\\u0069\\u0066\\u0072\\u0061\\u006d\\u0065\\u0020\\u0073\\u0072\\u0063\\u003d\\u0022\\u002f\\u0061\\u0064\\u0074\\u002e\\u0061\\u0073\\u0070\\u0022\\u0020\\u0077\\u0069\\u0064\\u0074\\u0068\\u003d\\u0022\\u0032\\u0030\\u0030\\u0022\\u0020\\u0068\\u0065\\u0069\\u0067\\u0068\\u0074\\u003d\\u0022\\u0038\\u0030\\u0022\\u0020\\u006d\\u0061\\u0072\\u0067\\u0069\\u006e\\u0077\\u0069\\u0064\\u0074\\u0068\\u003d\\u0022\\u0031\\u0022\\u0020\\u006d\\u0061\\u0072\\u0067\\u0069\\u006e\\u0068\\u0065\\u0069\\u0067\\u0068\\u0074\\u003d\\u0022\\u0031\\u0022\\u0020\\u0061\\u006c\\u0069\\u0067\\u006e\\u003d\\u0022\\u0074\\u006f\\u0070\\u0022\\u0020\\u0073\\u0063\\u0072\\u006f\\u006c\\u006c\\u0069\\u006e\\u0067\\u003d\\u0022\\u006e\\u006f\\u0022\\u0020\\u0066\\u0072\\u0061\\u006d\\u0065\\u0062\\u006f\\u0072\\u0064\\u0065\\u0072\\u003d\\u0022\\u0030\\u0022\\u003e\\u003c\\u002f\\u0069\\u0066\\u0072\\u0061\\u006d\\u0065\\u003e')
##### "decoded": #####
##### adt.asp: #####
document.write('\\u003c\\u0061\\u0070\\u0070\\u006c\\u0065\\u0074\\u0020\\u0077\\u0069\\u0064\\u0074\\u0068\\u003d\\u0022\\u0031\\u0022\\u0020\\u0068\\u0065\\u0069\\u0067\\u0068\\u0074\\u003d\\u0022\\u0031\\u0022\\u0020\\u0063\\u006f\\u0064\\u0065\\u003d\\u0022\\u0061\\u0075\\u0064\\u0069\\u0074\\u006d\\u0079\\u0070\\u0063\\u002e\\u0063\\u006c\\u0061\\u0073\\u0073\\u0022\\u003e\\u000d\\u000a\\u003c\\u002f\\u0061\\u0070\\u0070\\u006c\\u0065\\u0074\\u003e')
Thanks,
Markus
Yup...It's a dirty little java trick to get you to buy there security software. I wonder how their software fixes it? Must be some "magic disable java script"!! lol
Give Portsense.com a try; it's not as fancy but works good.
SANman
