I want to build a distributed vibration sensor using sagnac interferometer. how to eliminate the adverse polarization effects? some prior works utilized two polarization controllers ,one after the laser source and the other before the PD. I want to know exactly how they works and is there any other scheme?
Another question. If i just compose a single loop using a laser source , a detector , a 2*2 coupler and SM fiber, what will i see from the detector? The two counter-propagating waves have a pi/2*2=pi phase shift cause one of them passed across the coupler twice. Is it means that all light will go back to the source?
Thank you!
