Ethernet LAN multiple vlans at a single port
Subject Author Date
multiple vlans at a single port vicky 06-23-08
Posted by vicky on June 23, 2008, 1:13 am
can any body plz tell or explain me that :
Is it possible that at a single port of a L 2 switch there may be
multiple vlans, and if yes then please tell also a situation.
Thanks
Vikrant
Posted by Walter Roberson on June 23, 2008, 1:30 am
I don't see the difference between this question and ones you
asked about two or three weeks ago.
YES, a single port of a layer 2 switch may be a member of several
different VLANs. There can be a different VLAN for every
mechanically distinguishable characteristic of the packet.
In general, this includes whether the packet is UDP or TCP or which
subnet the source is, but that would involve layer 3 capabilities and
you have defined the situation as involving only a layer 2 switch.
A specific example is a Nortel Baystack 450, which is able to
create VLANs based upon several characteristics, such as whether
the packet is 802.2, 802.3 or SNAP.
Similar ThreadsPosted
multiple vlans at a single port June 23, 2008, 1:13 am
Multiple VLANs on Single NIC January 19, 2006, 8:06 am
Multiple PHYs to a single MAC April 11, 2007, 10:30 am
multiple DSL lines for single infrastructure March 17, 2005, 12:19 am
Security of multiple VLANs and WiFi March 3, 2005, 5:53 pm
multiple MACs on a port April 27, 2007, 7:53 am
Two different VLANs on the same port December 15, 2006, 8:02 am
Port Based VLANs September 10, 2006, 2:28 pm
Ethernet over single UTP April 19, 2005, 4:32 pm
difference b/w inter-switch link port and trunk port July 6, 2008, 12:06 pm
Netgear FVS 318 Wan Port to Ethernet Port on Alvarion ITU Problems... January 20, 2006, 4:55 am
1000BaseSX and Single Mode Fibre April 8, 2005, 12:15 pm
Ordered 5 single board computer ref. design, all are same MAC addr, what to do? February 14, 2006, 11:24 pm
Complete hangup of network caused by single device September 8, 2006, 5:01 am
10M full forced port connected to 100M full Duplex port March 25, 2006, 1:49 am
