Hello,
I'm looking for good solution to priority VoIP packages in routers. We have about 10 Cisco routers, and sometimes when someone downloading files from internet connection over VoIP telephone is slow/disconnent. Is this solution is good to priority packages:
access-list 100 permit ip any 'IP_VOIP_SERVER' access-list 100 permit ip 'IP_VOIP_SERVER' any
class-map test_speed match access-group 100
policy-map test class test_speed set ip precedence 5 class class-default set ip precedence 0
interface Ethernet0/0 service-policy input test
Maybe there is a better solution ? Those packages are only marked with higher prioryty, is this part of config I should write on all my routers'???
Thanks Pawel R.
