Hello,
I have a router at a remote site that's subject to vibration and suspect that the ethernet cable with RJ45 connector may be intermittently losing connection. Can someone tell me what best to look at in the counters...I would suspect an occasional CRC error, but don't see that, nor do I see anything that looks suspicious when I run "show interface f0" while viewing the counters. Are there any other stats I can check that might indicate a loose cable?
Thanks...
