I'm still mostly a n00b when it comes to OSPF, but I've been using it in a fairly basic fashion for a number of years. I'm really stuck on this one, since I have a similar config going on another router and it's working as I'd expect it to.
Hardware/Software Details: 1721 w/12.3(11)T5 IP BASE software, one T1 WIC, one ADSL WIC
Goal: both the T1 and ADSL lines come back to the same 7206. The T1 is frame converted to ATM at the dslam and long story short, that conversion doesn't let me see if the T1 is up or down from the 7206 side, so I'm running OSPF. ADSL is a backup line. I want OSPF to advertise the LAN block on the 1721 back to the 7206 and the 7206 to advertise default to the 1721.
Problem: Both routers are in area 0, and both see each other as neighbors. The 7206 has the 1721s loopback, serial ints and LAN ints in it's OSPF db and routing table. The 1721 has routes (including default) in the ospf db, but not in the routing table.
Brief config snippets from both:
7206: router ospf 1 router-id 10.10.111.1 log-adjacency-changes area 0 authentication message-digest passive-interface default no passive-interface ATM2/0.10246
OK, the authentication line was in there. I removed "redistribute connected subnets" as well, and then for good measure went ahead and cleared the ospf routing process. Still no default showing up (or any other routes via ospf).
Here's the output of "sh ip ospf database router", it's pretty long...
I also noticed this little weirdness in the first few entries that struck me as odd:
"(Link Data) Router Interface address: 0.0.6.214"
Thanks again for all your help...
Charles
Infinia#sh ip ospf database router
OSPF Router with ID (10.10.111.254) (Process ID 1)
Router Link States (Area 0)
Adv Router is not-reachable LS age: 536 Options: (No TOS-capability, DC) LS Type: Router Links Link State ID: 10.10.111.1 Advertising Router: 10.10.111.1 LS Seq Number: 800016C7 Checksum: 0xDF72 Length: 132 AS Boundary Router Number of Links: 9
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.110.1 (Link Data) Network Mask: 255.255.255.255 Number of TOS metrics: 0 TOS 0 Metrics: 1 Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.254 (Link Data) Router Interface address: 0.0.6.214 Number of TOS metrics: 0 TOS 0 Metrics: 2
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.104.1 (Link Data) Network Mask: 255.255.255.255 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.254 (Link Data) Router Interface address: 0.0.6.215 Number of TOS metrics: 0 TOS 0 Metrics: 33
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.3 (Link Data) Router Interface address: 10.10.111.25 Number of TOS metrics: 0 TOS 0 Metrics: 65 Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.111.24 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 65
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.3 (Link Data) Router Interface address: 10.10.111.13 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.111.12 (Link Data) Network Mask: 255.255.255.252 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.111.1 (Link Data) Network Mask: 255.255.255.255 Number of TOS metrics: 0 TOS 0 Metrics: 1
Adv Router is not-reachable LS age: 150 Options: (No TOS-capability, DC) LS Type: Router Links Link State ID: 10.10.111.3 Advertising Router: 10.10.111.3 LS Seq Number: 800030D0 Checksum: 0xB566 Length: 240 AS Boundary Router Number of Links: 18
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.112.0 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.208 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.1 (Link Data) Router Interface address: 10.10.111.26 Number of TOS metrics: 0 TOS 0 Metrics: 65
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.232 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.240 (Link Data) Network Mask: 255.255.255.240 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.118.128 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.111.16 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.1 (Link Data) Router Interface address: 10.10.111.14 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.111.3 (Link Data) Network Mask: 255.255.255.255 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.80 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.228 (Link Data) Network Mask: 255.255.255.252 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.204 (Link Data) Network Mask: 255.255.255.252 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.224 (Link Data) Network Mask: 255.255.255.252 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.72 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.64 (Link Data) Network Mask: 255.255.255.248 Number of TOS metrics: 0 TOS 0 Metrics: 1 Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.107.0 (Link Data) Network Mask: 255.255.255.192 Number of TOS metrics: 0 TOS 0 Metrics: 1
LS age: 1053 Options: (No TOS-capability, DC) LS Type: Router Links Link State ID: 10.10.111.254 Advertising Router: 10.10.111.254 LS Seq Number: 80000031 Checksum: 0x7D7F Length: 84 AS Boundary Router Number of Links: 5
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.108.16 (Link Data) Network Mask: 255.255.255.240 Number of TOS metrics: 0 TOS 0 Metrics: 1 Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.1 (Link Data) Router Interface address: 10.10.110.10 Number of TOS metrics: 0 TOS 0 Metrics: 130
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.110.0 (Link Data) Network Mask: 255.255.255.0 Number of TOS metrics: 0 TOS 0 Metrics: 130
Link connected to: another Router (point-to-point) (Link ID) Neighboring Router ID: 10.10.111.1 (Link Data) Router Interface address: 10.10.104.248 Number of TOS metrics: 0 TOS 0 Metrics: 65
Link connected to: a Stub Network (Link ID) Network/subnet number: 10.10.104.0 (Link Data) Network Mask: 255.255.255.0 Number of TOS metrics: 0 TOS 0 Metrics: 65
It looks like the LSA's are not be installed in the 1721's routing table because the LSA are flagged "Adv Router is not-reachable". There are several causes of this and you need to work thru to find out which one is occuring in your case.
see Cisco doc "Why Are Some OSPF Routes in the Database but Not in the Routing Table?"
Please post the complete configue for the 1721 and the 7206 interface config connected to the 1721.
Also post the config and the interface config for a comparable site that is working along with IOS version on the remote site along with "sh ip ospf database router" for the working site.
Thanks for the public one-on-one troubleshooting...
I think I can probably fix this by altering the config to use a dedicated /30 on each link. Right now both links are atm subifs on the
7206 and each interface uses an "ip unnumbered loopback X", which seems like it may be causing the "adv router not reachable" issue. This looks like it's addressed in that CCO doc you linked - I need to parse that more carefully. I'm going to try futzing and then post back. But in the meantime I'll put everything you asked for in here for the archives.
sample non-working config (note that my cvs config puller removes the md5 keys):
7206-
interface ATM2/0.10246 point-to-point ip unnumbered Loopback7 ip ospf authentication message-digest ! ip ospf message-digest-key 1 md5 ip ospf mtu-ignore pvc 0/10246 encapsulation aal5snap ! interface Loopback7 description loopback for 10.10.110.0/24 sdsl ip address 10.10.110.1 255.255.255.255 ! ip route 10.10.110.10 255.255.255.255 ATM2/0.10246
1721-
interface ATM0.1 point-to-point ip address 10.10.110.10 255.255.255.0 ip ospf authentication message-digest ! ip ospf message-digest-key 1 md5 7 ip ospf network point-to-point ip ospf mtu-ignore pvc 0/35 encapsulation aal5snap !
And now an example of a working config which uses numbered interfaces. Note that since there's no SDSL WIC that works with Nokia dslams this is bridged:
7206-
interface ATM4/0.12655 point-to-point bandwidth 1536 ip address 10.10.111.25 255.255.255.248 (using a /29 so I have an IP for bridge mgmt) ip ospf authentication message-digest ! ip ospf message-digest-key 1 md5 ip ospf mtu-ignore atm route-bridged ip pvc 0/12655 abr 1536 1536 encapsulation aal5snap !
3640-
interface FastEthernet0/0.3 description vlan 3 - sdsl to level3 circid - bandwidth 1536 encapsulation dot1Q 3 ip address 10.10.111.26 255.255.255.248 no ip proxy-arp ip ospf authentication message-digest ! ip ospf message-digest-key 1 md5 ip ospf network point-to-point ip ospf mtu-ignore
0.0.0.0 10.10.111.1 80 0x8000CC94 0x001517 1 router-568#sh ip route ospf 10.10.104.0/24 is variably subnetted, 2 subnets, 2 masks O 10.10.104.0/24 [110/68] via 10.10.111.13, 2d19h, FastEthernet0/0.2 O 10.10.104.1/32 [110/2] via 10.10.111.13, 2d19h, FastEthernet0/0.2 10.10.111.0/24 is variably subnetted, 5 subnets, 3 masks O 10.10.111.1/32 [110/2] via 10.10.111.13, 2d19h, FastEthernet0/0.2 10.10.110.0/24 is variably subnetted, 2 subnets, 2 masks O 10.10.110.0/24
(FE 0/0.2 is a 10Mb metro ether line, FE 0/0.3 is a 1.5Mb SDSL line terminated on a bridge)
As to the post regarding numbering, it is correct.
Lastly, the interface info for both the 7206 and 1721 (note that the network types match):
7206-
router-l3t#sh ip ospf interface atm 2/0.10246 ATM2/0.10246 is up, line protocol is up Internet Address 0.0.0.0/0, Area 0 Process ID 1, Router ID 10.10.111.1, Network Type POINT_TO_POINT, Cost: 2 Transmit Delay is 1 sec, State POINT_TO_POINT, Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5 Hello due in 00:00:04 Index 306/306, flood queue length 0 Next 0x0(0)/0x0(0) Last flood scan length is 2, maximum is 2 Last flood scan time is 0 msec, maximum is 0 msec Neighbor Count is 1, Adjacent neighbor count is 1 Adjacent with neighbor 10.10.111.254 Suppress hello for 0 neighbor(s) Message digest authentication enabled Youngest key id is 1
1721-
Infinia#sh ip ospf interface serial 0.1 Serial0.1 is up, line protocol is up Internet Address 10.10.104.248/24, Area 0 Process ID 1, Router ID 10.10.111.254, Network Type POINT_TO_POINT, Cost: 65 Transmit Delay is 1 sec, State POINT_TO_POINT, Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5 oob-resync timeout 40 Hello due in 00:00:04 Supports Link-local Signaling (LLS) Index 1/1, flood queue length 0 Next 0x0(0)/0x0(0) Last flood scan length is 1, maximum is 1 Last flood scan time is 0 msec, maximum is 4 msec Neighbor Count is 1, Adjacent neighbor count is 1 Adjacent with neighbor 10.10.111.1 Suppress hello for 0 neighbor(s) Message digest authentication enabled Youngest key id is 1
I think that's all the info... I need to investigate this unnumbered issue, I think that will take me somewhere.
It was the numbered+unnumbered issue linked above. Should have posted my interface configs right off the bat, sorry about that. I'm so used to the unnumbered stuff since 99.999% of our lines are setup that way... habit.
Infinia#sh ip route ospf | inc 0.0.0.0 O*E2 0.0.0.0/0 [110/1] via 10.10.111.221, 00:01:54, Serial0.1
Now I just have to clean things up and I think this is all good to go.
One more question, for a site like this where it's just two lines with one backing the other up, should I just look at setting up another area? This is a pretty rare config for us, so I'm tempted to leave it as-is, and I've never played with stub areas or NSSA's... Any opinions on that?
