what wins? static route or static route learned ospf E2 (both has same metric)
my understanding is that static route that I put in by hand wins and if that fails it goes to the E2 learned OSPF correct?
Yes. Static routes have admin distance of 1 and will win over OSPF routes. Doan
Read the full replywhat wins? static route or static route learned ospf E2 (both has same metric)
The static route.
Doan
There is also a form of static route known as a floating static router on which you configure the admin distance that the static route should have.
By default static routes have an admin distance of 1 so they are preferred over all other routes other than connected wihich have an admin distance of 0 and ALWAYS win.
Floating static routes are useful in a number of scenarios including backup
