Finally, after two weeks of playing with my simulator and trying to get encapsulated vlans to talk, I determined that the Boson NetSim does not route traffic between vlans using dot1q correctly.
I am wondering what everyone is using for network simulators that you can design a layout of a network and manage all the devices to work on commands, routes, access-lists, etc.
I know it's not what you want to hear, but there's nothing like the real thing....pretty much all simulators I've come across have errors and can confuse the hell out of you..and Boson is probably the worst for it.
If you're looking at CCNA level, then Routersim
is pretty good and will teach you what you need to know (ACL's, VLAN's, NAT/PAT etc)., along with a user-friendly interface. For CCNP and above/similar, then I'd highly recommend buying your own kit, most stuff is fairly cheap on ebay, although you may not be allowed to upgrade the IOS image.
also supports the 3600/3700/2691 emulated hardware) with NM switch module. "
I have had a bit of a look at the one Doug mentined and it is pretty nice. It runs real code and in my experience operated correctly. I have done a bit of frame relay and ospf on it. It needs a bit of general computer experience to get going and so may not be suitable for everyone but I am REALLY impressed so far.
It does need a lot of memory so I suggest trying the 3600 version first and don't go too crazy with the IOS, try to save memory.
It needs real IOS image.
One of the neatest things is that you can run the simulated routers on as many computers as you have and it all behaves perfectly. i.e. If one PC runs out of resources and you need more routers you can add more on different PCs just as easily as you add them to the first one. One router is simulated on one PC. This is because the simulator architecture is such that it uses IP to communicate between the simulated routers even on the local PC and so it is trivial and almost invisible to the user to move indivual simulated routers to a different host.
BTW someone said that it did 1000pps (or was it 100?) so don't bother to think about using it in production.
