To whom it may concern:
I created a multilink for my upgraded bonded T1. I used S0/0 and s0/1 as my multilink interface. Everything works fine for all of the users except for the users that are on E1/0. Before the upgrade the E1/0 interface connected users to the WiFi subnet and that worked fine. After the multilink upgrade, I can not get E1/0 to route users to the virtual multilink interface so that they can get out to the Internet. How do I connect the WiFi interface to the virtual multilink interface? You can email me if you want.
Thanks
Rich the SE for the Chamber
Here is my config
interface Multilink1000 (Virtual Interface) description Miltilink for S0/0 and S0/1 ip address xxx.xx.xxx.xxx 255.255.255.252 no cdp enable ppp multilink ppp multilink fragment-delay 500 multilink-group 1000 ! interface FastEthernet0/0 (Private LAN) ip address xx.xxx.xxx.xxx 255.255.255.240 speed auto full-duplex ! interface Serial0/0 (Part of the Multilink) bandwidth 1544 no ip address no ip redirects no ip proxy-arp ip nat outside encapsulation ppp ip route-cache flow no fair-queue service-module t1 timeslots 1-24 ppp multilink multilink-group 1000 ! interface FastEthernet0/1 (A subnet and not in use) ip address xxx.xxx.xx.x 255.255.255.0 shutdown duplex auto speed auto ! interface Serial0/1 (The other part of the multilink) no ip address no ip redirects no ip proxy-arp encapsulation ppp ip route-cache flow no fair-queue service-module t1 timeslots 1-24 no cdp enable ppp multilink multilink-group 1000 ! interface Ethernet1/0 (The problem WiFi Interface that will not route to DNS) ip address 192.168.xx.x 255.255.255.0 ip nat inside half-duplex ! router rip version 2 redistribute connected network 19x.16x.x.x (This is from the subnet that is not being used) no auto-summary ! ip nat pool ovrld xx.xxx.xxx.xxx xx.xx.xxx.249 prefix-length 24 ip classless ip route 0.0.0.0 0.0.0.0 xxx.xx.xxx.xxx no ip http server ip pim bidir-enable ! access-list 7 permit 192.168.xx.x 0.0.0.255 (This is equil to E1/0's network) dialer-list 1 protocol ip permit snmp-server community GCCC RO banner motd ^CWARNING: Do Not Attempt to Gain Access to this Network>
Under Penalty of Law^C ! line con 0 line aux 0 line vty 0 1 password 7 050909152E login line vty 2 4 password 7 00021F0F144B0E14 login ! no scheduler allocate end
PrivateRout#sh int FastEthernet0/0 is up, line protocol is up Hardware is AmdFE, address is 0001.42a6.8960 (bia 0001.42a6.8960) Internet address is xx.xxx.xxx.xxx/28 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:03, output 00:00:00, output hang never Last clearing of "show interface" counters never Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 33000 bits/sec, 21 packets/sec 5 minute output rate 245000 bits/sec, 28 packets/sec 6567453 packets input, 1658473459 bytes Received 3870 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 7802974 packets output, 2016412372 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Serial0/0 is up, line protocol is up Hardware is PQUICC with Fractional T1 CSU/DSU MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 2/255, rxload 19/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open, multilink Open Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 5d22h Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 116000 bits/sec, 16 packets/sec 5 minute output rate 13000 bits/sec, 14 packets/sec 3932491 packets input, 3135385273 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 3367805 packets output, 814408898 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
FastEthernet0/1 is administratively down, line protocol is down Hardware is AmdFE, address is 0001.42a6.8961 (bia 0001.42a6.8961) Internet address is xxx.xxx.xx.2/24 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Serial0/1 is up, line protocol is up Hardware is PQUICC with Fractional T1 CSU/DSU MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 19/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open, multilink Open Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 5d22h Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 116000 bits/sec, 14 packets/sec 5 minute output rate 12000 bits/sec, 9 packets/sec 3938948 packets input, 3143847996 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 3309917 packets output, 801276796 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 1 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Ethernet1/0 is up, line protocol is up (This is the problem Interface) Hardware is AmdP2, address is 0001.42a6.8970 (bia 0001.42a6.8970) Internet address is 19x.16x.x0.2/24 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:03, output 00:00:06, output hang never Last clearing of "show interface" counters never Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 213260 packets input, 17368284 bytes, 0 no buffer Received 206227 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 61046 packets output, 5817357 bytes, 0 underruns 0 output errors, 1 collisions, 1 interface resets 0 babbles, 0 late collision, 51 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Multilink1000 is up, line protocol is up Hardware is multilink group interface Description: Miltilink for S0/0 and S0/1 Internet address is xxx.xx.xxx.250/30 MTU 1500 bytes, BW 3080 Kbit, DLY 100000 usec, reliability 255/255, txload 2/255, rxload 19/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 2 seconds on reset LCP Open, multilink Open Open: IPCP Last input 00:00:02, output never, output hang never Last clearing of "show interface" counters 5d22h Queueing strategy: fifo Output queue 0/40, 13767 drops; input queue 0/75, 0 drops 5 minute input rate 240000 bits/sec, 28 packets/sec 5 minute output rate 31000 bits/sec, 21 packets/sec 7758390 packets input, 1936585510 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 6564647 packets output, 1561791222 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions PrivateRout#
