PIX 506E Configuration Issue
Nov 19, 2005 1 Replies
I'm a PIX newbie and I'm having a problem with what should be a simple and common configuration.
The PIX sits between my DSL modem and the switch for my internal network. I have a single static, routable IP address (in addition to the gateway address) and my internal network uses private addresses (192.168.1.x).
I want to use PAT to translate my internal private addresses into the single public static IP address on the outside interface. I also have several servers on my internal network that I want to redirect to from the single public IP based on port as follows:
66.124.x.y:25 -> 192.168.1.2:25
66.124.x.y:53 -> 192.168.1.2:53
66.124.x.y:119 -> 192.168.1.7:119
DSL PIX Switch Internal Network
66.124.x.z 66.124.x.y 192.168.1.1 192.168.1.2-10
Here's part of my PIX config (I don't have it all here, so this is just the relevant parts):
nameif ethernet0 outside security0 nameif ethernet1 inside security100 ip address outside 66.125.x.y 255.255.255.248 ip address inside 192.168.1.1 255.255.255.255 hostname firewall nat (inside) 1 0 0 global (outside) 1 66.124.x.y route outside 0.0.0.0 0.0.0.0 66.124.x.z static (inside,outside) tcp 66.124.x.y smtp 192.168.1.2 smtp netmask \\
255.255.255.0 0 0 static (inside,outside) udp 66.124.x.y domain 192.168.1.2 domain \\ netmask 255.255.255.0 0 0 static (inside,outside) tcp 66.124.x.y 119 192.168.1.7 119 netmask \\
255.255.255.0
I've omitted the ACLs that permit the inbound mail, DNS, and NNTP traffic...
Here's my problem--the PIX 6.3 configuration manual says this of the syntax of the static command: "Replace global_ip with the outside (global) IP address. In general, this is the interface with the lower security level. This address *cannot* be a PAT IP address."
There lies the rub: if I only have a single static IP address, how can I use it as the translation address for outgoing PAT and the global IP address for the static command when the manual says it cannot be a PAT address? Am I doing something wrong, or is this a limitation of the PIX software?
[snip]
Mine (501) is like:
ip address outside A.B.C.D 255.255.255.255 pppoe ip address inside 192.168.208.1 255.255.255.0
(I'm running the PPPoE client on my pixie with:)
access-list outside_in permit tcp any interface outside eq www access-list outside_in permit tcp any interface outside eq https global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface www 192.168.208.10 www netmask
255.255.255.255 0 0 static (inside,outside) tcp interface https 192.168.208.10 https netmask 255.255.255.255 0 0 access-group outside_in in interface outside
Works fine. Getting the "default" route into mine (running 6.3.5) was amusing. I think the command I used was "route outside 0.0.0.0 0.0.0.0 pppoe". Good ole' PIX OS reported some crap about OSPF MIB errors then promptly started routing packets..
I've found that paying "too much" attention to the documentation can be detrimental.. Hope that helps.
