Hi, I am doing a test.I have 3 routers cisco 805,2500 and 1600.
The cisco 2500 will do a frame relay switching and has the following setup: interface Serial0 no ip address encapsulation frame-relay no ip route-cache bandwidth 64 no keepalive frame-relay intf-type dce frame-relay route 16 interface Serial1 16 ! interface Serial0.1 point-to-point no ip address ! interface Serial1 no ip address encapsulation frame-relay no ip route-cache bandwidth 64 no keepalive frame-relay intf-type dce frame-relay route 16 interface Serial0 16 ! interface Serial1.1 point-to-point no ip address
The cisco 805 has the following serial configuration:
interface Serial0 bandwidth 64 no ip address encapsulation frame-relay IETF no ip mroute-cache no keepalive ! interface Serial0.1 point-to-point ip address 172.21.3.2 255.255.255.252 frame-relay interface-dlci 16
THe cisco 1600 has :
interface Serial0 bandwidth 64 no ip address encapsulation frame-relay IETF no ip mroute-cache no keepalive ! interface Serial0.1 point-to-point ip address 172.21.3.1 255.255.255.252 frame-relay interface-dlci 16
My problem is that i can not ping from the cisco 805 to the cisco 1600
sh frame relay pvc:
DLCI = 16, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0
input pkts 0 output pkts 0 in bytes 0 out bytes 0 dropped pkts 0 in FECN pkts 0 in BECN pkts 0 out FECN pkts 0 out BECN pkts 0 in DE pkts 0 out DE pkts 0 pvc create time 0:28:00 last time pvc status changed 0:27:29 Num Pkts Switched 0
Pls can anybody help me ???
Thanks
