According to the Cisco 10-Gigabit Ethernet Transceiver Modules Compatibility Matrix the only 10GE module with copper interface that will plug into a 3750E is the X2-10GB-CX4. This has an InfiniBand 4X connector and is designed to use CX4 cable.
I'm trying to find a 10GE NIC that is compatible with this module. Has anyone here successfully connected something to this module?
Do I need a 10 GE NIC or a Host Channel Adapter such as this?
Is the Infiniband 4x connector also known as CX4/SFF-8470?
Any help you can provide will be most appreciated. Bob Simon New Orleans
