Gigabit Ethernet connector
Jun 13, 2005 4 Replies
Jump to replies (4)
I've certainly never heard of one. What makes you think one exists? Have you considered running a cable right to the board?
Hi All,
I´m designing a digital board in which I need a Gigabit interface over copper (1000Base-T).The problem is that I don´t have enough space for the RJ-45 connector, and I´m wondering if there exists other kinds of standard conector, smaller than RJ45.
Thanks!
Delivered via
no-spam access to your favorite newsgroup -
comp.dcom.lans.ethernet - 1780 messages and counting!
You might try an SATA connector--it's not a lot smaller but it's flatter and the impedance is right. Just make sure you label it so that nobody tries to connect it to a disk or disk controller. A couple of the smaller Firewire connectors might work--Firewire is, I understand, 110 ohm, which should be close enough as long as you're not pushing the limit on cable length, but you'd need to use two of them as they're only two-pair. And good luck connecting a CAT5e cable to either.
Hi All,
I need to find a standard gigabit connector (1000BaseT) smaller than the RJ45, is there any? It´s driving me almost crazy finding one!!
Thanks!
Article posted with Cabling-Design.com Newsgroup Archive
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.lans.ethernet - 2924 messages and counting!
Other than the RJ45 (and maybe the 110 punch block) there are no standards-compliant connectors for TP Ethernet. I'd say your only option would be to run a cable directly to the board, ensuring crosstalk, impedance, and other parameters are within spec.
What are you trying to fit this into that an RJ45 is too big?
