I recently moved to a area with faster internet access then I previously had. I am able to connect directly to the cable modem (comcast) and download starting at 2.0mb/s and it trickles down to about 1.4mb/s from my dedicated host. When I utilize my Cisco 3725 router in the mix router the performance is very poor. It may burst for a second or two but downloads about 100kb/s and I've repeated these results on a Vista box and a Apple notebook. Here's my Config from my router.
Any tips on why I'm having such poor performance with my router would be greatly appreciated. I have tried disabling the built IDS but that didn't seem to make a difference.
Internet -> F0/0 router F1/1.2 -> host 172.16.2.X
! ! Last configuration change at 00:20:30 EST Mon Oct 27 2008 by rsreese ! NVRAM config last updated at 00:22:28 EST Mon Oct 27 2008 by rsreese ! version 12.4 service timestamps debug datetime msec service timestamps log datetime service password-encryption ! hostname 3725router ! boot-start-marker boot system flash:/c3725-adventerprisek9-mz.124-21.bin boot-end-marker ! logging buffered 8192 debugging logging console informational enable secret 5 ! aaa new-model ! ! aaa authentication login default local aaa authentication ppp default local aaa authorization exec default local aaa authorization network default local ! aaa session-id common clock timezone EST -5 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 network-clock-participate slot 1 network-clock-participate slot 2 no ip source-route ! ip traffic-export profile IDS-SNORT interface FastEthernet0/0 bidirectional mac-address 000c.2989.f93a ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 172.16.2.1 ip dhcp excluded-address 172.16.3.1 ! ip dhcp pool VLAN2clients network 172.16.2.0 255.255.255.0 default-router 172.16.2.1 option 66 ip 172.16.2.10 option 150 ip 172.16.2.10 dns-server 68.87.74.162 68.87.68.162 68.87.73.242 ! ip dhcp pool VLAN3clients network 172.16.3.0 255.255.255.0 default-router 172.16.3.1 dns-server 68.87.74.162 68.87.68.162 68.87.73.242 ! ! ip domain name neocipher.net ip name-server 68.87.74.162 ip name-server 68.87.68.162 ip inspect udp idle-time 900 ip inspect name SDM_LOW cuseeme ip inspect name SDM_LOW dns ip inspect name SDM_LOW ftp ip inspect name SDM_LOW h323 ip inspect name SDM_LOW https ip inspect name SDM_LOW icmp ip inspect name SDM_LOW netshow ip inspect name SDM_LOW rcmd ip inspect name SDM_LOW realaudio ip inspect name SDM_LOW rtsp ip inspect name SDM_LOW sqlnet ip inspect name SDM_LOW streamworks ip inspect name SDM_LOW tftp ip inspect name SDM_LOW tcp ip inspect name SDM_LOW udp ip inspect name SDM_LOW vdolive ip inspect name SDM_LOW imap ip inspect name SDM_LOW pop3 ip inspect name SDM_LOW esmtp ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 ip ips sdf location flash://256MB.sdf ip ips notify SDEE ip ips name sdm_ips_rule vpdn enable ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! crypto pki trustpoint TP-self-signed-995375956 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-995375956 revocation-check none rsakeypair TP-self-signed-995375956 ! ! crypto pki certificate chain TP-self-signed-995375956 certificate self-signed 01
quit ! crypto key pubkey-chain rsa named-key realm-cisco.pub signature key-string quit username rsreese privilege 15 secret 5 ! ! ip ssh authentication-retries 2 ! ! crypto isakmp policy 3 encr 3des authentication pre-share group 2 ! crypto isakmp policy 10 hash md5 authentication pre-share crypto isakmp key address 10.0.0.2 no-xauth crypto isakmp key address 74.245.61.45 no-xauth ! crypto isakmp client configuration group VPN-Users key dns 68.87.74.162 68.87.68.162 domain neocipher.net pool VPN_POOL acl 115 include-local-lan netmask 255.255.255.0 crypto isakmp profile IKE-PROFILE match identity group VPN-Users client authentication list default isakmp authorization list default client configuration address initiate client configuration address respond virtual-template 1 ! ! crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac mode transport ! crypto ipsec profile IPSEC_PROFILE1 set transform-set ESP-3DES-SHA set isakmp-profile IKE-PROFILE ! ! crypto dynamic-map DYNMAP 10 set transform-set ESP-3DES-SHA ! ! crypto map CLIENTMAP client authentication list default crypto map CLIENTMAP isakmp authorization list default crypto map CLIENTMAP client configuration address respond crypto map CLIENTMAP 1 ipsec-isakmp set peer 10.0.0.2 set peer 74.245.61.45 set transform-set ESP-3DES-SHA match address 100 crypto map CLIENTMAP 10 ipsec-isakmp dynamic DYNMAP ! ! ! ! interface Loopback0 ip address 192.168.0.1 255.255.255.0 no ip unreachables ip virtual-reassembly ! interface Tunnel0 description HE.net no ip address ipv6 address 2001:470:1F06:3B6::2/64 ipv6 enable tunnel source 68.156.61.58 tunnel destination 209.51.161.14 tunnel mode ipv6ip ! interface Null0 no ip unreachables ! interface FastEthernet0/0 description $ETH-WAN$$FW_OUTSIDE$ ip address dhcp client-id FastEthernet0/0 hostname 3725router ip access-group 104 in no ip unreachables ip nat outside ip inspect SDM_LOW out ip ips sdm_ips_rule in ip virtual-reassembly speed 100 full-duplex crypto map CLIENTMAP ! interface Serial0/0 description $FW_OUTSIDE$ ip address 10.0.0.1 255.255.240.0 ip access-group 105 in ip verify unicast reverse-path no ip unreachables ip inspect SDM_LOW out ip virtual-reassembly clock rate 2000000 crypto map CLIENTMAP ! interface FastEthernet0/1 no ip address no ip unreachables ip virtual-reassembly duplex auto speed auto ! interface FastEthernet0/1.2 description $FW_INSIDE$ encapsulation dot1Q 2 ip address 172.16.2.1 255.255.255.0 ip access-group 101 in no ip unreachables ip nat inside ip virtual-reassembly ipv6 address 2001:470:1F07:3B6::/64 eui-64 ipv6 enable crypto map CLIENTMAP ! interface FastEthernet0/1.3 description $FW_INSIDE$ encapsulation dot1Q 3 ip address 172.16.3.1 255.255.255.0 ip access-group 102 in no ip unreachables ip nat inside ip virtual-reassembly ! interface FastEthernet0/1.10 ! interface Serial0/1 no ip address no ip unreachables shutdown clock rate 2000000 ! interface Virtual-Template1 type tunnel description $FW_INSIDE$ ip unnumbered Loopback0 ip access-group 103 in no ip unreachables ip virtual-reassembly tunnel mode ipsec ipv4 tunnel protection ipsec profile IPSEC_PROFILE1 ! ip local pool VPN_POOL 192.168.0.100 192.168.0.105 ip forward-protocol nd ip route 172.16.10.0 255.255.255.0 10.0.0.2 ! ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ip nat translation udp-timeout 900 ip nat inside source list 1 interface FastEthernet0/0 overload ! logging trap debugging logging origin-id hostname logging 172.16.2.5 access-list 1 permit 172.16.2.0 0.0.0.255 access-list 1 permit 172.16.3.0 0.0.0.255 access-list 100 permit ip 172.16.2.0 0.0.0.255 172.16.10.0 0.0.0.255 access-list 100 permit ip 172.16.2.0 0.0.0.255 172.31.12.0 0.0.0.255 access-list 101 remark auto generated by SDM firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 permit ahp any host 172.16.2.1 access-list 101 permit esp any host 172.16.2.1 access-list 101 permit udp any host 172.16.2.1 eq isakmp access-list 101 permit udp any host 172.16.2.1 eq non500-isakmp access-list 101 permit ip 172.16.10.0 0.0.0.255 172.16.2.0 0.0.0.255 access-list 101 deny ip 10.0.0.0 0.0.15.255 any log access-list 101 deny ip 192.168.0.0 0.0.0.255 any log access-list 101 deny ip 172.16.3.0 0.0.0.255 any log access-list 101 deny ip host 255.255.255.255 any log access-list 101 deny ip 127.0.0.0 0.255.255.255 any log access-list 101 deny tcp any any range 1 chargen log access-list 101 deny tcp any any eq whois log access-list 101 deny tcp any any eq 93 log access-list 101 deny tcp any any range 135 139 log access-list 101 deny tcp any any eq 445 log access-list 101 deny tcp any any range exec 518 log access-list 101 deny tcp any any eq uucp log access-list 101 permit ip any any access-list 102 remark auto generated by SDM firewall configuration access-list 102 remark SDM_ACL Category=1 access-list 102 deny ip 172.16.2.0 0.0.0.255 any log access-list 102 deny ip 10.0.0.0 0.0.15.255 any log access-list 102 deny ip 192.168.0.0 0.0.0.255 any log access-list 102 deny ip host 255.255.255.255 any log access-list 102 deny ip 127.0.0.0 0.255.255.255 any log access-list 102 permit ip any any access-list 103 remark auto generated by SDM firewall configuration access-list 103 remark SDM_ACL Category=1 access-list 103 deny ip 172.16.2.0 0.0.0.255 any access-list 103 deny ip 10.0.0.0 0.0.15.255 any access-list 103 deny ip 172.16.3.0 0.0.0.255 any access-list 103 deny ip host 255.255.255.255 any access-list 103 deny ip 127.0.0.0 0.255.255.255 any access-list 103 permit ip any any access-list 104 remark auto generated by SDM firewall configuration access-list 104 remark SDM_ACL Category=1 access-list 104 permit udp host 205.152.132.23 eq domain any access-list 104 permit udp host 205.152.144.23 eq domain any access-list 104 remark Auto generated by SDM for NTP (123) 129.6.15.29 access-list 104 permit udp host 129.6.15.29 eq ntp any eq ntp access-list 104 permit ahp any any access-list 104 permit esp any any access-list 104 permit udp any any eq isakmp access-list 104 permit udp any any eq non500-isakmp access-list 104 deny ip 10.0.0.0 0.0.15.255 any log access-list 104 permit ip 172.16.10.0 0.0.0.255 172.16.2.0 0.0.0.255 access-list 104 deny ip 172.16.2.0 0.0.0.255 any log access-list 104 deny ip 192.168.0.0 0.0.0.255 any log access-list 104 deny ip 172.16.3.0 0.0.0.255 any log access-list 104 permit udp any eq bootps any eq bootpc access-list 104 permit icmp any any echo-reply access-list 104 permit icmp any any time-exceeded access-list 104 permit icmp any any unreachable access-list 104 deny icmp any any echo log access-list 104 deny icmp any any mask-request log access-list 104 deny icmp any any redirect log access-list 104 deny ip 10.0.0.0 0.255.255.255 any log access-list 104 deny ip 172.16.0.0 0.15.255.255 any log access-list 104 deny ip 192.168.0.0 0.0.255.255 any log access-list 104 deny ip 127.0.0.0 0.255.255.255 any log access-list 104 deny ip 224.0.0.0 15.255.255.255 any log access-list 104 deny ip host 255.255.255.255 any log access-list 104 deny tcp any any range 6000 6063 log access-list 104 deny tcp any any eq 6667 log access-list 104 deny tcp any any range 12345 12346 log access-list 104 deny tcp any any eq 31337 log access-list 104 deny udp any any eq 2049 log access-list 104 deny udp any any eq 31337 log access-list 104 deny udp any any range 33400 34400 log access-list 104 deny ip any any log access-list 105 remark auto generated by SDM firewall configuration access-list 105 remark SDM_ACL Category=1 access-list 105 remark Auto generated by SDM for NTP (123) 129.6.15.29 access-list 105 permit udp host 129.6.15.29 eq ntp host 10.0.0.1 eq ntp access-list 105 permit ahp host 10.0.0.2 host 10.0.0.1 access-list 105 permit esp host 10.0.0.2 host 10.0.0.1 access-list 105 permit udp host 10.0.0.2 host 10.0.0.1 eq isakmp access-list 105 permit udp host 10.0.0.2 host 10.0.0.1 eq non500- isakmp access-list 105 permit ip 172.16.10.0 0.0.0.255 172.16.2.0 0.0.0.255 access-list 105 permit udp host 10.0.0.2 host 172.16.2.10 eq tftp access-list 105 permit udp host 10.0.0.2 host 172.16.2.5 eq syslog access-list 105 deny ip 172.16.2.0 0.0.0.255 any access-list 105 deny ip 192.168.0.0 0.0.0.255 any access-list 105 deny ip 172.16.3.0 0.0.0.255 any access-list 105 permit icmp any host 10.0.0.1 echo-reply access-list 105 permit icmp any host 10.0.0.1 time-exceeded access-list 105 permit icmp any host 10.0.0.1 unreachable access-list 105 deny ip 10.0.0.0 0.255.255.255 any access-list 105 deny ip 172.16.0.0 0.15.255.255 any access-list 105 deny ip 192.168.0.0 0.0.255.255 any access-list 105 deny ip 127.0.0.0 0.255.255.255 any access-list 105 deny ip host 255.255.255.255 any access-list 105 deny ip host 0.0.0.0 any access-list 105 deny ip any any log access-list 115 permit ip 172.16.0.0 0.0.255.255 any access-list 120 deny ip 172.16.0.0 0.0.255.255 192.168.0.0 0.0.0.255 access-list 120 permit ip 172.16.0.0 0.0.255.255 any snmp-server community public RO ipv6 route 2001:470:1F07:3B6::/64 FastEthernet0/1.2 ipv6 route ::/0 Tunnel0 ! ! ! ! control-plane ! ! ! ! ! ! ! ! ! ! line con 0 line aux 0 line vty 0 4 password 7 transport input ssh line vty 5 903 transport input ssh ! ntp clock-period 17180660 ntp server 129.6.15.29 source FastEthernet0/0 prefer ! end
