Now with pictures!
Subject
- Posted on
November 15, 2007, 3:29 pm
Can anyone tell me how to connect to my Catalyst 1900 switch using SSH? I
can connect without problem to the console using a rollover cable in my PCs
COM port but I'd also like to connect via the switches IP address. I can't
find any documentation on how to set a password for an SSH (or Telnet)
session in the switches configuration & when I try to connect using puTTY I
get the message "Network error: Connection refused"? I'm starting to think
that maybe the 1900 can't accept SSH or Telnet connections but I doubt this
very much.
TIA, Jason.
very much.
TIA, Jason.
Re: Using SSH to connect to a Catalyst 1900 switch
Jason wrote:
conf t
line vty 0 4
login
password cisco
wri mem
That will get you telnet access, as far as SSH I beleive you have to
have a certain IOS train to use SSH.
You do have an IP address on the switch already, correct? Can you ping
the address?
conf t
line vty 0 4
login
password cisco
wri mem
the address?
Chuck it out, and buy a switch that hasn't been EOL'd since almost
before ssh existed (exagerating here)? The generation after this one
didn't support SSH either..
You can telnet to it when you configure remote access in the menus.
Read up on the docs here.
<http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/catalyst1900_2820/version9.00.00/icgf/19icg9x.html#wp9129>
Network Management Menu->IP Configuration Menu
Setup your IP address and password.
Yeah I'm starting to gather that. I'm studying for my CCNA & I inherited
the lab I'm using from a friend who did his CCNA a few years ago. Much of
the syntax also differs quite a lot from the Catalyst 2960 that my study
book uses to give examples, which is quite frustrating; can you recommend
something more modern that I might be able to pick up on eBay fairly
cheaply?
Thanks, Jase
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » 1700 Debug
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » checking for a heartbeat
- — The site's Newest Thread. Posted in » Wireless Networking
