Switch help
I have a 1900 running Cisco Catalyst 1900/2820 Enterprise Edition Software Version V8.01.02.
I have to make alot of changes to the ports, going from half duplex to full duplex.
Is there a command that I can do this with instead of doing it one by one?
CLI only!!
Many thanks
F.
Anonymous
Yes, it is:
sw1(config)#int range gi4/1 - 24 sw1(config-if-range)#
or if you want select few ports instead of some range, you can use this:
sw1(config)#int range gi4/1 , gi4/2 , gi4/5 , gi4/16 sw1(config-if-range)#
-- KriS
KriS
I saw that command while I was looking onine for a answer. When I type that in I get
1900A(config)#int ? Ethernet IEEE 802.3 FastEthernet FastEthernet IEEE 802.3 1900A(config)#int range ? % Unrecognized command
Any Ideas?
Anonymous
You may need to upgrade the IOS or this switchs may not support this command.
Alan Searcy
i think that not all cisco ios supports that command.
if you can't use the range command, try doing
(config)# interface f0/1-f0/24
again, not all ios support these command
technodewa
IIRC, you might have been able to do it (ironically) within the GUI.
Hansang Bae
