ok, look at Doan's posts, he gives an answer (not on his flash cards). And Doan said another (dfiferent) answer (that matched his flash cards) is very good.
Ignore CCNA Nerd's explanation. If you have a look at the responses, you'll see it wasn't rated very highly. And was a bit amateurish, as you noticed .
I'm throwing my hat into the ring..... And I realize it's only worth two cents....
This is yet another example of a broken practice test question that are part of all of these products, regardless of the vendor, Test Kind, Boson, I don't care who it is. These people are trying to cash in on the Cert bandwagon and give give a rat's tail on proofing their materials.
It is never a good idea to create a route summarization statement that includes subnet space which is not actually available. As such, there is NO SINGLE summarization statement that can be created which will account for the subnets listed, and ONLY those subnets listed. The only statement which would include all the subnet space listed is a /18. However, doing this would not be wise because dozens of additional subnets would be included in that single statement. This is would be "bad." It's called "over summarizing."
The "best" answer would be to simply leave everything alone and advertise the 6 individual routes as they are and not create any ambiguity downstream.
Use these products with caution!
Better yet, just learn the material and trust in the force.
I could have sworn the "certification bandwagon" came to a screeching halt about five years ago, right along time the tech boom went down in flames. Did I miss a revival? Does Transcender still command $150 and up per exam simulation?
I have read through this entire thread, and I have seen many of your posts, Mr. Sharp. My observation is this. Your posts are a real distraction. As if you are a grown up class clown. You say a lot, but nothing of any consequence. I would like to suggest that if you have nothing constructive to post, perhaps it would be better to leave things alone.
LOL. I love posts like yours. My observation is this: You, Parr snipped-for-privacy@hotmail.com, have never posted to this newsgroup before. Yet you're already a self-annointed moderator. Moderate THIS, shit for brains!
When we look at the bits that don't change we get 10xxxxxx so the summary that includes them all is 10.0.128.0/18
So we have a little problem. If what we wanted to summarise started at 128, we would have a simple summary, but we are including quite a bit more in the summary than we need.
Where we have a portion that does not change - 101 then we get two bits where we get all values from all 0s to all ones, then we get the host portion. We can thus summarise this octet as 10100000 mask 11100000 - 10.0.160.0 /19
While learning it is quite important to go to the binary. I have 20 years in networks, and still drop to the binary once in a while.
Once you *understand* what you are doing with the actual bits, you will get used to the number patterns.
According to CISCO the summarization consists of the common leftmost bits. In your case the first two octets are the same, so no need of writing them down in binary. The third octets in binary are as follows:
10001000 (136)
10001111 (143)
the common leftmost bits are:
10001xxx (136)
It's just a coincidence that 136 is the same number.
So, the summarization of the two IPs will be 172.21.136.0. What I do not get is the format: how did it change from /24 to /21? What's the logic behind it?
Sorry - sloppy terminology on my part - what I should really have said is thatth address space we are trying to summarise is contiguous.
Look at the numbers, and the bit about subtract from 256 giving 8. That means for the /21 mask the third octet incerements by eight, but to try to throw you a little they put two four in - looking at the binary helps - two fours are eight, so together they are one /21.
Nope - the first two bits of the third octet are the two that don't change so that's 18 bits altogether.
Practice!
To really get this off pat, you need to *understand* the binary, and that the address field is really a 32 bit integer. subnetting and summarisation are basically logical operations on binary numbers.
If yu are asking that, the best thing I can say is look at the binary, look at the patterns of the bits.
