STP question
Threaded View
Would be a bit confusing, but probably draw a diagram and it will make
If there are 3 switches, A,B&C. Assume Swtich A is the root bridge. The link
between A&B is 10Mbps, A&C is 100Mbps, C&B is 100Mbps.
In this case, all the ports on A is set to "forwarding". The port on C which
connects to A is set to "forwarding" since it is where it receives the low
cost helo BPDU. The port on B connecting to C receives the lowest cost helo
BPDU, it is set to "forwarding".
What happens to the Port on C, which connects to B.
My actual question is can 2 ports on a non-root switch be set to
Apologies if my question doesn't makes sense, I am still in learning state.
Re: STP question
On Tue, 25 Jul 2006, raj wrote:
The basic STP algorithm is:
1) Elect the root switch - switch A in your example.
2) On non-root switches,
   a) elect the root port (lowest cost to the root switch)
      Switch A will select the A-C link since the cost is the 100Mbps (as
      compare to the C-B-A link (cost 100MB).  For simplicity, let say the
      cost of the 100MBps = 1 and the 10MBps = 10, the cost for the A-C
      link is then 1 and the cost for the C-B-A link = 1 + 10 or 11.
      Switch B will select the B-C-A since the cost is 2 (100Mbps
      +100Mbps) where as the B-A link is 10!
   b) elect the designate port the local LAN segment (lowest cost wins).
      On the B-C link, C wins because C has lower cost.
So, in you example, the two ports on switch A will be "forwarding"; two
ports on switch C will be "forwarding; the port from B to C will be
"forwarding" while the port from B to A will be "blocking".
Re: STP question
Makes a lot of sense now. Thanks Doan.
Site Timeline
