route from router to layer3 switch
Threaded View
hi,
i am using a router of 3800 series and a layer3  Catalyst 4507 switch.
i want that my data will transfer from the layers thee switch to all
the users. i have 2 ethernet ports of router and i configer the
private ip address on both
my ip at ethenet are 168.10.40.5
                               10.0.0.141
and my ip at the layer 3 switch are as under
10.0.0.1
can any body help me to define a proper route to send all traffic from
router to layer3 swith then to all users.
Re: route from router to layer3 switch
Could you tell us what IP addresses the users fall under?  Is it
10.0.0.0 subnet?  If so, are they plugged into the Catalyst 4507? If
they are all on the same switch, and on the same VLAN, the data should
automatically be switched between them
Site Timeline
