No CDP?
Threaded View
Hello all,
I'm going for my CCNA and I have built a home lab with:
2 - Cisco 2501's
1 - Cisco 2502
1 - Cisco 2507 (access server)
1 - Catalyst 2924M-XL 24port switch
1 - Catalyst 2924-XL 24port switch (no M in this one)
The problem I have is that on one of my 2501's I do not have ANY CDP
commands.. I think I may have screwed the pooch on something so can
someone tell me if I have an outdated IOS, and if I do, how much does
it cost to upgrade and is it worth it?  Thanks..here is the version
output:
Cisco Internetwork Operating System Software
IOS (tm) 3000 Software (IGS-BPX-L), Version 10.0(8), RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-1994 by cisco Systems, Inc.
Compiled Tue 14-Feb-95 21:06 by dougs
Image text-base: 0x0301F9D4, data-base: 0x00001000
ROM: System Bootstrap, Version 4.14(9.1), SOFTWARE
R2-2501 uptime is 57 minutes
System restarted by reload
System image file is "igs-bpx-l.100-8", booted via flash
cisco 2500 (68030) processor (revision D) with 4092K/2048K bytes of
memory.
Processor board serial number 01741850
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Bridging software.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Authorized for Enterprise software set.  (0x0)
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2102
HELP!
Re: No CDP?
I recommend you.. to enforce your lab... with a Cisco emulator 7200
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
it realy going to help you.
regards
Re: No CDP?
Your ios is ancient (feb 95). you need to upgrade
you have 8mb flash and 4mb ram so you might
need to increase at least your ram before you can
upgrade to a more recent ios.
What don't you start by borrowing the ios from one
of the other routers.
Posted via a free Usenet account from http://www.teranews.com
Re: No CDP?
how do I do that? I'm pretty new and I'm reading 5 books on CCNA/
Networking, but I'm in the theory of all of that now...would i use the
copy tftp command or what?
Thanks!
Re: No CDP?
Yes, copy the desired file to your tft server and then
from the server to the other router.
#copy   c2500.js.-12.2.20.bin    tftp
on the other router you have to go through the ios upgrade precdure:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800941aa.shtml
make sure it fits in the flash mem.
Re: No CDP?
Site Timeline
