To add links to a multilink bundle, what command should be used? A. ppp multilink B. Enable chap C. Multilink ppp D. Enable multilink E. dialer load-threshold TK Answer: E
How abt A?
How abt A?
this is really a tricky question, the answer depends from the perspective, if you do not add ppp multilink to the config it will not participate of the bundle (and if is a simple serial i would say that is what is simply needed), but talink about bris....
" To configure bandwidth on demand by setting the maximum load before the dialer places another call to a destination, use the dialer load-threshold command in interface configuration mode. "
I thought it was ppp multilink also.
Adil
If the question stated how do you create a multilink bundle then C would be correct. The way the question is worded the bundle is already created, you are simply adding additional links to it, that being said E is the best answer.
-Brian
I guess u got it right Brian.
