Take this scenario in: T1 line, 4 Computers, 1 Network Printer, Cisco 2501 T1 Router
How well would it work if I just used an Active hub to allow additional connections to the Cisco router?
I just want to setup something very simple for someone, however I can use a switch if the above scenario doesn't work well. I was thinking about using an intelligent hub.
You'll need an Ethernet transceiver to go from the AUI (15 pin) Ethernet connector to a RJ45 for the connection to the hub (or low-end switch). Use a 8-port hub or switch. Then cable the router to one port of the hub-switch and the other devices to the other ports. Do _not_ use the 'uplink' port on the hub/switch to connect to the router (unless you can turn off the 'uplink' feature or have a cross-over Ethernet cable). A T-1 will work quite well for these users. Of course, you have a DSU/CSU between the router's serial interface and the T-1 from the carrier, right?
BTW, my troubleshooting 'kit' includes a 8 port dumb hub and a selection of known good Ethernet cables. The dumb hub allows you to capture/analyze traffic without setting up a SPAN port, which I'm not aware of _any_ low-cost switch being able to do.
The router has a built in DSU/CSU unit. Yes, I know not to use the uplink for a bridge over connection like that. I don't think a hub would hurt them much, not with such a low amount of nodes.
Also, why can't I just plug a Cat5 cable from > > Take this scenario in:
A 2501 does NOT have a built in CSU/DSU nor does it have any built in ethernet ports. A 2501 has 2 DB60 serial ports and 1 built in AUI port. If it is really a 2501 that you have you will without a doubt need a CSU/DSU with a acb-v35 cabke as well as a AUI tranceiver to plug the ethernet into.
Perhaps you have a different model router?
As far as a hub, why the heck would you do that? You can get a cheapo linksys 8port 10/100 switch for less than 50$. Hubs are bad news and shouldn't be used in this day and age.
Red This and run fast beyond my 1600. Taken a crossover (indeed very happy to use that old crossover cable there useless, and have a brand new straighthrough to use where it was missing). Plug from eth1 to uplink in the switch...NAA..didn't work!! Too good to be ok!! What switch do you use from a Cisco (or router) to a uplink getting it to work too? Yeah, i havent a superYeah switch Catalyst or something to plug crossover too, but if it works i though it was ok it too. Going to try at school plugging a crossin a superYeah 2950. Please let me know ( my switch is a 30 bucks 10/100 writtenontheboxAUTOeverything 8 port+uplink writtenonthebox stackable).
Not if it is a 2501. 2501 has 2 HD60 serial ports and one Ethernet AUI connection, plus the con and aux ports. If you have a built-in dsu/csu and rj45's for the Ethernet, then you _do not_ have a 2501.
So, which model of router do you have? if it is a modular router (there are/were some modular 25xx series) then which modules are installed?
brian, I don't recommend installing a hub for normal use, but having a dumb hub for troubleshooting purposes (you can capture all packets between devices, which you can't do with a switch unless you can set up a SPAN port) is a must in my kit.
Yea, and he does not have a 2501 if it has builtin dsu/csu or rj45 for Ethernet. maybe one of the modular 25xx's (was it a 2525?).
Way saying: didnt know i can use the uplink port in a switch with a crossover. In fact, it doesnt work on my switch.. it works only with straighthrough
think of it this way: 'normal' ports on a hub/switch are DCE. A client device (e.g. router or computer) is a DTE. An 'uplink' port is a DTE interface, whereas all the other ports are DCE. The 'uplink' port is intended to plug into a normal port of another hub/switch.
An 'uplink' port does a cross-over inside the port, so you can use a normal Ethernet patch cord (straight-thru) to connect to a device port of another hub/switch. So, if you want to connect the uplink to another client device, like a router or computer, you'll need either a way to turn off the internal cross-over (typically the uplink port will have a push-button next to it), or externally use a cross-over cable, which in effect cancels out the internal cross-over.
Or, I _could_ be all wrong. But that's the way my 4 and 8-port netgear, linksys, and several off-brand, hubs/switches work.
