Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Bob Dozier on April 5, 2005, 8:50 pm
Please log in for more thread options Those of you who have had 'hands on' - which do you think is best for terminating F, RCA, and BNC fittings? Pros and cons? Thanks | |||||||||||||||||||||||||||||||
Posted by Ed Nielsen on April 5, 2005, 10:26 pm
Please log in for more thread options Bob Dozier wrote: Hex-crimp creates 6 points of impedance mismatch, which is a source of reflections. Reflections, of course, can cause standing wave (analog) and/or packet collision (digital). I once went on a service call where a few of their DirecTV channels were missing. Not a few transponders, but a few channels. Replaced the hex-crimp fittings at the LNB, and back they came. Compression fittings also have a much higher return loss (>30dB) than
hex-crimp (~18dB).
I once saw a copy of a sweep trace of a high rise building in which hex-crimp fittings were used. You could see every floor on the trace. Compression fittings have a better pullout strength than hex-crimp. Most of them also have internal O-rings, which makes them more moisture resistant. They may be a little more expensive (not that much, though), but the time saved in both the initial installation and subsequent service calls (there won't be any with compression fittings done right) makes them well worth the extra few cents. You can read a little more about some compression fittings here | |||||||||||||||||||||||||||||||
Posted by Bob Dozier on April 6, 2005, 11:53 am
Thanks for your post. Can anyone recommend a compression tool? Some RJ45 tools are no good all. Any recommendation of a source of compression tools and connectors for F, RCA, and BNC fittings? Thanks! ....Bob > Bob Dozier wrote:
> > for terminating F, RCA, and BNC fittings? Pros and cons? Thanks > > > > > Compression, without a question.
> > Hex-crimp creates 6 points of impedance mismatch, which is a source of > reflections. Reflections, of course, can cause standing wave (analog) > and/or packet collision (digital). I once went on a service call where > a few of their DirecTV channels were missing. Not a few transponders, > but a few channels. Replaced the hex-crimp fittings at the LNB, and > back they came. > > Compression fittings also have a much higher return loss (>30dB) than > hex-crimp (~18dB). > > I once saw a copy of a sweep trace of a high rise building in which > hex-crimp fittings were used. You could see every floor on the trace. > > Compression fittings have a better pullout strength than hex-crimp. > > Most of them also have internal O-rings, which makes them more moisture > resistant. > > They may be a little more expensive (not that much, though), but the > time saved in both the initial installation and subsequent service calls > (there won't be any with compression fittings done right) makes them > well worth the extra few cents. > > You can read a little more about some compression fittings here > <http://www.cencom94.com/gpage1.html>. | |||||||||||||||||||||||||||||||
Posted by Ed Nielsen on April 6, 2005, 11:22 am
<http://www.cencom94.com/gpage.html2.html> for tools (The CPLCCT-LM will
do all 3 connectors of the Digicon (F-Conn) brand), and
<http://www.cencom94.com/gpage1.html> for the connectors.
CIAO! Ed N. Bob Dozier wrote: > Thanks for your post. Can anyone recommend a compression tool? Some RJ45
> tools > are no good all. Any recommendation of a source of compression tools and > connectors > for F, RCA, and BNC fittings? > > Thanks! > > ...Bob | |||||||||||||||||||||||||||||||
Posted by Bob Dozier on April 6, 2005, 2:59 pm
Again, thanks for your post. Yet another question from this newbie... It seems that there are different connectors for braided cable and quad-shield? - S-Series BNC Connectors for RG 59 - S-Series BNC Connector for RG 59 Quad-Shield Cable Since I have not purchased the Siamese RG-59 cable yet (this is for CCTV cameras), which is considered the best way to go 95% copper braid or quad-shield? There is much info available when I google - just wanted some suggestions from those with experience with it. Thanks! ....Bob > <http://www.cencom94.com/gpage.html2.html> for tools (The CPLCCT-LM will
> do all 3 connectors of the Digicon (F-Conn) brand), and > <http://www.cencom94.com/gpage1.html> for the connectors. > > > CIAO! > > Ed N. > > Bob Dozier wrote: > > Thanks for your post. Can anyone recommend a compression tool? Some RJ45
> > tools > > are no good all. Any recommendation of a source of compression tools and > > connectors > > for F, RCA, and BNC fittings? > > > > Thanks! > > > > ...Bob | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| compression or crimp | April 5, 2005, 8:50 pm |
| Siamese Compression Fittings | August 24, 2005, 8:20 pm |
| BNC Compression Fittings w/ Siamese Cable | August 24, 2005, 8:20 pm |
| How to crimp RCA connectors onto RG59 coax | July 11, 2006, 4:12 pm |
| What's the right way to terminate RG6 Quad with F-Conn compression connectors? | January 20, 2005, 12:26 am |
| Fibre optic crimp / terminate tool kit.. | June 9, 2005, 10:17 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
