Is there any real advantage of using cat 3 for inside wiring for a DSL installation when the drop to the residence is only a POTS line? The baud rate would be limited by the drop, I would imagine, but would the added CAT 3 (or better) make real difference with signal quality? Underground drops aren't readily replaced by phone companies around here.
Thanks for replies! Greg
