Voyager 2091 & Belkin G USB 54bits help
Feb 12, 2006 0 Replies
Trying to set up a Voyager 2091 & Belkin G USB adapter but not having a lot of luck(suprise!) Anyway after eliminating all other possibilities I have come to the conclusion that either the adapter or the router has a fault (the range is verry poor) but how do I know which one to take back to the shop (is there a way to test them?)and if I take the USB adapter back should I get a wireless PCI card? any recomendation?
TIA Progger
