static nat not working
Jan 05, 2006 0 Replies
i'm dying here...can anyone figure this out. here's the issue: trying to connect from outside to inside thru pix501 running 6.3(3). I have no problem getting from host A to host B on the inside using static NAT but when I try to get from host A to host C on the inside, I get this TCP request discarded error.
I want to be able to connect from hostA to pixInt port 35354, which the pix should then nat to hostC (192.168.2.191) on port 61234 and doesn't work. when I connect to pixInt port 35353 it gets converted quite nicely to port 80 on hostB
305011: Built static TCP translation from inside:192.168.2.191/61234 to outside:pixInt-IP/35354
302013: Built inbound TCP connection 15016 for outside:HostA-IP/4183 (HostA-IP/4183) to inside:192.168.2.191/61234 (pixInt-IP/35354)
710005: TCP request discarded from HostA-IP/4184 to outside:pixInt-IP/61234
pertinent lines from config:
static (inside,outside) tcp interface 35354 192.168.2.191 61234 netmask
255.255.255.255 0 0 access-list 100 permit tcp any interface outside eq 35354
HELP PLEASE!!!
