wireless usb for canon camera?
Jun 24, 2007 0 Replies
I have a program that came with my Canon camera (S3is) called ZoomBrowser. The program allows me ( with a USB cable--small fitting on the camera end; "regular" fitting on the other... that plugs into my computer) ) to control the camera's functions from ten feet away.
BUT..I have to run the cable outside... through window-screening etc. Is a device made that will allow me to eliminate the cable over 20 feet or so? If so, where might I find it; what is it called; and does anyone have an idea what the approx cost would be to put together such a rig?
I'm a newbie at all of this ( as you can no doubt tell) ..
thanks very much. Rich
